Ignicolist
Hi all:
I'm designing a steel structure. This structure consist on welded steel plates (with different, but similar thicknes).
My main issue is that I find a lot of probles while dimensioning the thicknes of weldings.
I made a "hand calculation" of the forces in the position of the weldings, but comparing with FEM calculation, I find that in the point where deformation is higher, FEM stress is higher. This is clear, as in hand calculation all plates are considered rigid. In addition, the calculations are simplified because the structure is quite complicated.
I would like to know how to dimension the weldings. First of all regarding static force and then considering fatigue. I would like to dimension them to achieve "infinite" life, or at least more than 30.000 cicles.
I can easily calculate the structure with FEM, but I don't know how to dimension the weldings with these results.
I would appreciate any help and if additional information is needed, just ask and I can provide it.
Thanks in advance for your help
