UnneutralAxis
- Apr 5, 2009
- 54
Strange situation here. I have a contractor that is supplying some structural items for an industrial application. They ran this scenario by me.
Don't bother with the whys. I got caught up in the whys for about an hour and I'm not sure why it HAS to be this way yet either.
A 18' long HSS10x8x0.5 has 2" diameter holes @ 2' o.c. on the 10" deep faces. They want to insert another smaller HSS tube into the 10x8 and weld them together at the 2" hole locations. They originally sent me a sketch showing an HSS7x4 inside the larger tube (no theoretical clearance at all). I told them they would be extrememly lucky if the small tube would fit inside. Now they want to get a smaller interior tube and weld plates to it to give approx. 1/4" of play between the two faces. This way they can insert the smaller tube into the HSS10x8 and not have too large a gap for welding.
I am thinking if you add the tolerances of each tube together, as well as accounting for straightness, there would need to be a pretty good gap to ensure the fit of an 18' long tube inside another. Possibly too much of a gap to weld acceptably for the entire length? What are your thoughts?
