Not to share, you need to have your procedure qualified and then the welder certified. Typically a coupon is prepared using such a procedure with appropriate quality control(s), then the welder follows said receipe step-by-step to completion. The coupon is submitted for testing to a specification, to which the procedure and welder either pass or fail.
Wish it was as easy as looking up a weld procedure and then calling it good. You need to be aware of the engineering law in your particular region, I suggest starting there.
Cockroach
