Drawoh,
So this begs the question. Can you heat treat the welded area ? It would be nice to weld a sub assembly then heat treat and age a part. but somehow I suspect that the weld deposit would not play nicely. There are still too many un answered questions here.
The other question here is, would the weld take the HAZ to the annealed condition, or would it take it to the AQ condition?
The article makes the statement "What's more, it is believed that post-welding heat treatments could boost the strength of the 7075 welds up to 551 megapascals, which is on par with the weld strength of steel.". This may be true for the alloy but I want to see test results on the welds before I believe that.
B.E.
You are judged not by what you know, but by what you can do.
