Having said that, you may be a fool not to qualify the welder to make groove welds in very thin materials (production welder qualification), even when you have a WPS so qualified.
Base metal thickness is not an essential welder performance variable except for OFW (oxyfuel gas welding). However weld deposit thickness is one. If he is qualified to deposit 8.18 mm of weld thickness then he can deposit weld of any thickness up to 16.36 mm.
Note that base metal thickness is an essential variable for welding procedure qualification. If the procedure qualified on 8.18 mm coupon then the approval range is from 1.5 mm to 16.36 mm.
