What do you do when bolt holes in a shear tab don't line up? (For those unfamiliar with the term, a shear tab is a plate welded to the supporting member and bolted to the web of the supported member.) Sometimes, due to fabrication or erection issues, the holes in the shear tab don't line up with the holes in the supported beam web. So the easiest thing to do is to weld the shear tab to the supported member, right? See the attached sketch. But then you have a connection that doesn't allow for any end rotation, so your model of a pinned connection is no longer valid. Indeed, AISC doesn't recognize this connection type.
My question is, does anybody know of any research or documentation on these types of connections? This is a common problem, and the common proposed remedy is "weld the shear tab to the supported beam web."
