I have the situation where I have a plate fillet welded to a beam at 50 degrees from the horizontal. Because of this angle the weld throat thickness is reduced on one side of the plate and increased on the other.
I discussed with a colleague who advised that the welding codes (both British Standard and AWS) do not allow you to take a throat thickness larger than 0.707 x Leg Length for an acute angle in design, and conversely specify that a weld over an obtuse angle must be built up to ensure a minimum throat thickness of 0.707 x Leg.
I have been unable to find a reference to this in any of BS's I looked at, and do not have access to AWS D1.1.
Could someone advise if this is the case, and where I could find the supporting information?
![[pimp] [pimp] [pimp]](/data/assets/smilies/pimp.gif)
"The world keeps turning, it keeps me in my place; where I stand is only three miles from space"
Spiritualized
Spiritualized
