Is the weld on a 2:1 SE cover on a manway for an ASME VIII Div 1 vessel covered by the Code.
We have several large stamped vessels to be installed in a nuclear waste clean up plant, that after shop hydro and National Board stamping are delivered with a tacked welded 2:1 SE head as a manway cover. All the piping connections on the vessels are butt welded and it is necessary to inspect these vessels for internal cleanliness prior to placing them in service, hence the loose manway cover.
The vessels are designed for 40 years life and are in radioactive service and will therefore not be subject to further inspection once commissioned. In fact the vessels are enclosed in totally inaccessible cells within the processing buildings.
The question is, does the welding of the manway cover need to be covered by ASME VIII by way of an R stamp or can this weld be considered a piping weld under ASME B31.3 similar to all the other butt welds connecting the piping.
This is probably territory for an ASME interpretation but I'm curious to know if anyone has encountered a similar situation previously.
