Greetings. I am designing a continuous aluminum beam, 2 spans, with square tube section, 6063-T5. the ends of beam and intermediate supports are to be welded to another aluminum beam.
The welded yield strength is much less than the non-welded, and the code specifies that the welded strength shall apply to 1" section from center of weld. So - Does it mean that I will have to use the welded yield strength at intermediate support to resist the huge negative moment? If the weldment is only at bottom of the tube section and is very minimal, it does not make sense to reduce the strength by using the welded yield strength.
What is your take on this?
