Weldable steel 1
WWTEng
How do I determine if existing structural steel is weldable? The project is from 1955 and the column size is W10x49. I can't find the material properties (fy, f'c etc) in the existing drawings.
Thanks.
A column in a 1955 building would be weldable. What does f'c have to do with a steel column?
hokie, thanks. I guess I was pointing out that there are no material properties listed, steel or concrete.
If you are concerned find a spot to clean off and drill and have the material analyzed. Odds are low C and decent chemical balance, should weld fine.
Plymouth Tube
My 5th edition AISC Manual (copyright 1947) indicates in Section 9 of the Specification that structural steel shall conform to ASTM A7. For ASTM A7 material, Fy = 33 ksi.
We were using 33ksi yield back then. History here.
Michael.
"Science adjusts its views based on what's observed. Faith is the denial of observation so that belief can be preserved." ~ Tim Minchin
