metrosteel10520
Thank you all for taking the time to read this.
I have a question about welding rebar to the flanges of a wide flange column. The design called out a flare beveled groove weld, see attached. We used this weld where it applies, where the rebar is parallel to the flange. However, where the rebar is perpendicular to the flange this weld is not possible. We used a ½”filet weld-all around at this location. The Project Engineer was looking for a Full Penetration Weld to be applied here. Does the ½” Fillet Weld bring the rebar to full strength and thus satisfy this requirement?
Thanks in advance.
Thanks in advance.
