Weld study (Fillet)
  • Thread starter Thread starter shinoy
  • Start date Start date
S
shinoy
Guest
Hi All,
Season's Greetings!
I have seen many post which talks about the method of creating welds.
But do anybody can suggest the best method to study the fillet weld in Creo Simulate. I am using Creo2.
I have used pro weld option and then you creo simulate option, which is yielding different results(may be I am wrong in any of the steps I went through), and I am confused now.
I have used a chamfered model for Creo Simulate and without chamfer for pro weld.
Please enlighten me with your great knowledge.
Shinoy
Dear Shinoy,
Of course the result will be different as you add weld mass and run CAE the effective response will be different.If you couls capture the screen shot and exactly can show me the problem I can guide you better.
still below link can help you plz go through it.
ENGINEERING.com | File Downloads
