Good Morning BMoorthy. Thank you for responding to my inquiry. The head in question is:
ASME 2:1 SE,
11.58 meters inside diameter,
28.58 mm minimum thickness,
50.8 mm straight flange,
Construction: 3.66 meter crown plate with 13 equal petal segments. The joint design is double bevel 60% outside with a root opening of 2.38 mm and a 3.18 mm landing. Tack welds are used for normal fit up.
We plan to roll the shell after the head is welded in order to match shell circumference to head circumference. ASME addresses the allowable over/under tolerances for formed heads in UG-81.d based on the nominal diameter of the head. However ASME doesn't appear to define what is meant by "nominal diameter" and what the permissable deviation from the "nominal diameter" might be.
From your response I understand that the buyer is required to specify a tolerance for the circumference measurement. Are you aware of any industry standard circumferential tolerance to be used in the absense of a buyer specified acceptable tolerance? Does ASME require the buyer to specify the circumference tolerance somewhere in the Code? I haven't been able to find any reference to buyer specified circumferential tolerances in the code.
At the time of Fitup/Setup do you normally allow 5 mm more than the permitted circumference tolerance for all sizes of heads or do you allow 5 mm per foot of head diameter or do you use some other formula.
Out of curiosity are you with a Head Manufacturer/Vessel Fabricator?
Thanks for your help, Kent.
