A small nozzle hole was incorrectly placed and repaired by using the material drop from the correct hole as the plug for the incorrectly located opening, and the weld was LP tested.
If the calculations were originally performed using a seamless ellip head with "E" value noted below...
Efficiency, Longitudinal Seam 0.85
Efficiency, Circumferential Seam 0.65
Do I have to change the Long Seam E value to 0.7 because of the weld repair?
