Weld between steel & bronze
minez
5
I have a bronze sculpture to anchor onto a concrete base.
The sculpture weighs about 3000 lbs with 10 ft height.
Is it possible to weld bronze material to steel plates embedded in concrete? Is there any other common way to secure sculptures?
Thanks,
I think putting the bronze in contact with the steel has corrosion potential. You may want to research this before you connect them in any way.
