drivefast
Automotive
- Dec 21, 2007
- 32
I have a valve cover that has several bolt holes around the flange. Each bolt hole has a rid on one side and a raised and angled, offset threaded bolt on the other. Each bolt hole is identical except for location and angle I know I can join the parts in an assem. and use that to create a new part by joining all the features but then I can no longer easily make changes to the part. If I need to change something on the sketch I have to do it on the pre-asssem. part. Is there an easier way?
