Is there any way I can store nodal solution data (like displacemnt, temperature, etc..at certain nodes) at every substep into an array or a matrix just like *GET command does for every load step?
I tried OUTRES command but I could only retrieve the results manually (using GUI). There should be some other way when you think of many substeps.
What's the magic command I'm missing here?
Thanks a lot.
Thanks a lot.
