Water tank design- bolts and distances 1
Jimmypacific
Chemical
Jul 15, 2010
5
I am designing a corrugated iron water tank where multiple sheets need to be joined together. How to determine the shear flow/stress in the tank walls and therefore the size and spacing of bolts required to keep it together..?
Once the hoop stress is determined in the tank walls..where to next?
There are design manuals for water tanks. I don't recall where right now but I am sure that someone with a better memory will be along shortly.
Plymouth Tube
Why don't you purchase a bolted, steel water tank? Many are epoxy coated. Just for curiosity, I checked and found numerous options and suppliers. Why re-invent the wheel? Otherwise, better get a copy of this manual
AWWA D103-97 – Bolted steel tank fabrication and erection
API 12B (bolted tanks) ...It's already done for you from 100 bbl.s to 18,000 bbl.s
Thank you for the advice. I am working in Cambodia implementing rainwater harvesting systems for poor housholds and schools so purchasing a pre-fab tank is outside the price range, hoping we can design and build a cheap one from material here to contain potable water.
