I have a situation in a water distribution system with a 200 GPM service pump where the first encountered residents are experiencing "hammer" problems in their homes. we have taken pressure readings in the system and static pressure is 105 PSI. when the pump turns on, pressure goes to 140 psi and when it shuts off, pressure drops to 55 and then returns to 105. Is this situation considered water hammer? Is there any recommendations on how to eliminate this problem. The residents are blowing their water meters, not to mention dealing with these pressure flucuations!
