I am working on a field with Lufkin pumps producing from a reservoir about 2000 m below the surface and into flowlines around 2000 m long to a separator station. Production is typically three phase but I suspect that it is sometimes 100% liquids.
Flow calculations for the flowlines indicates wellhead end pressures for the flowline should vary from 500 to 1100 kPa as the pump flow goes from 0 (bottom of stroke) to maximum (half way up stroke) but we are seeing pressure peaks up to 2300 kPa. I have run transisent calculations (water hammer) which predict pressures up to 2000 kPa when the lines are liquid filled and believe the system may be experiencing this.
Problem is that we have pressure switches installed to trip the wells at 1850 kPa to protect the 150 lb piping system.
Is anyone aware of water hammer happening in these systems? Dennis Kirk Engineering
