thread378-399464
In my previous thread, i was looking for guidance on how to calculate what was happening on the upstream side of a quick closing valve. Thanks for all who provided insight.
But there is another aspect of water hammer I have not seen much information/guidance I can use to design to minimize the effects. That is the resultant column separation that can occur on the downstream side of the valve.
I understand the flow momentum of the water downstream of the valve causes the pressure to fall below the vapor pressure of water and forms a vacuum (cavitation) which eventually reverses direction as the vapor bubbles implode and another positive pressure water hammer occurs on that side of the valve.
But I have not found any calculation methods which can provide numerical values for the pressures involved, something similar to Joukowski.
Are there sources I could look for, hopefully with examples?
Thanks in advance
Thanks in advance
