Bkg73321
- Feb 18, 2017
- 8
Was hoping to find a calculator online that i could plug this data into simply but can't find. Tried to teach myself the calculations i found but didn't stick. Could someone please calculate this and explain how you calculated it if you have time?
Trying to calculate the GPM Flow Rate at the open air outlet for the following hypothetical residential water system.
Entire system is PEX 1/2 ID tubing.
Inflow at entry ground level 95PSI @ 10.75GPM.
Immediately goes up vertical 8FT.
Then horizontal 8FT.
Then down vertical 6FT into a water filter.
The water filter restricts the flow rate to 7GPM on its outlet.
Upon exiting the filter the tubing then goes up vertical 6FT.
Then horizontal 10FT.
Then down vertical 4FT.
Then horizontal 2FT.
Then up vertical 4FT.
Then horizontal 40FT.
At this point the water flows freely from the end of the tubing at atmospheric pressure.
For simplicity no elbows or tees or couplers.
Can you please tell me what the flow rate in GPM will be at the outlet?
Thank you so much!
Sincerely,
Brandon
Thank you so much!
Sincerely,
Brandon
