Water-Driven vacuum pump 1
pperlich
114
I am looking for a vacuum pump for air that is driven by flowing water. The pump must be able to move at least as much air (volume) at atmospheric pressure as water (volume) that flows through it. The water would be coming from a garden hose. Does anything like this exist?
You're looking for a water powered ejector.
Search for that and you find people like this
whether it will do what you want is probably down to the available pressure at the ejector.
Thanks for the reply, but that's not quite what I'm after.
The water and air can't be mixed in my situation.
EDIT: Actually now that I think about it a little more maybe this could work. If you could get the volume of the air drawn in to equal or be slightly more than the volume of water it could work.
Looks good - twice as much air flow as water flow.
If you can get this from a $25 piece of plastic, you can probably get a bit more form a bigger metal one.
Thanks guys (or gals), that looks like it will work!
