Thanks Racook here are answer to your Qs:
What temperature, pressure, and humidity is ambient? It is indoor air, temp in range of 72-104degF, atm ; RH in range 40-80% not sure the exact condition at the time we go for it , you may consider the worse case
Air right? Not heated nitrogen or argon or something else? Air
How long will the pipe "stand" with air flow in the pipe (at the above conditions) to "dry" the interior, if any time at all, before you need it "dry" for your process? 5 days,before we blow air into piping to preserve it for long plant overhaul.
Gravity drain: vertical pipe or horizontal or sloped? If sloped, at what angle from the horizontal? piping is combination of them. Consider 1% sloped pipe
Are you going to pass a desiccant over the pipe walls? A wiper or pig or rag? NO
How clean are the pipes that you want to dry? Is the water "standing up" from surface tension on a clean smooth surface, or it is covering the wall because the wall is dirty or oily or covered in scale and mill debris? Standing up from surface tension
"Normal" pipe, or does it have a covering like chrome or plastic or fiberglass? Normal
