DominicASP
Materials
I am trying to find the water concentration in ppmv of an air mixture and determine the effect of lowering the total pressure of the mixture on this water concentration.
Firstly, I would like to know if the formulas used to find the ppmv value are correct. Here's my procedure:
Working conditions:
T = 23 Celsius
Relative Humidity (RH) = 44%
Ptot = 1011 mbar
Step 1 - Find the Vapor Saturated Pressure (Pws) at Temperature (T) using a Saturation Vapor Pressure over Water Table:
For T = 23 Celsius, I find 28.086 mbar
Step 2 - Find the Vapor Partial Pressure (Pw):
Pw = RH * Pws
Step 3 - Find the Air Partial Pressure (Pa):
Pa = Ptot - Pw
Step 4 - Find the Absolute Humidity (AH):
AH = (RH * 0.622 * Pws) / Pa
Step 5 - Knowing the Absolute Humidity, find the ppmv:
ppmv = (Ma / Mw) * AH * 10^6
Reorganizing last equation, we find:
ppmv = (29/18) * {[RH*0.622*Pws]/[Ptot - (RH*Pws)]} * 10^6
For my conditions, I find:
ppmv = (29/18) * {[0.44*0.622*28.086]/[1011-(0.44*28.0866)]}*10^6 = 12401
Is that procedure correct and does it have certain limits (ex: RH value, pressure value, etc.) that would make its use incorrect?
If not, how could I determine the ppmv value for a water vapor/air mixture knowing the total pressure of the mixture and the relative humidity?
Secondly, regardless if the procedure described above is right or wrong, I would like to know the effect of lowering the total pressure of the air/vapor mixture on the water ppmv value.
If I based my reasoning on the ppmv formula above, lowering the total pressure would result in an increase in the water ppmv value.
Assuming an air/water vapor mixture in a closed system with the ambient conditions described above, at constant temperature, where, using a vacuum pump, I gradually lower the pressure of the mixture. How would the ppmv water concentration value change as the pressure lowers? Would it behaves linearly? How could this be explained using the perfect gas law?
Working conditions:
T = 23 Celsius
Ptot = 1011 mbar
Pw = RH * Pws
Pa = Ptot - Pw
