ivanhoe374
Chemical
We are currently running a trial plant on the wastewater from a food manufacturer. The existing plant is an activated sludge plant with the decant entering into a 100,000L tank before being discharged to sewer.
From this tank we are attempting to recycle the water using a combination of ultrafiltration, activated carbon and reverse osmosis.
The problem we are having is quite severe fouling of the RO membranes (10% drop over 3hrs). Our lab has identified the problem to most likely be Calcium Phosphate.
Can anyone recommend an effective method for removing the calcium phosphate, i have heard that Lanthanum chloride can be used to precipitate out calcium phosphate, which could then be filtered out in the UF system....does anyone have any experience with this? and if so what pH, dose rates etc would i be looking at?
Does anyone have any other suggestions?
One other thing we have noticed is that with an SDI test we seem to be getting a light yellow coloured stain on the SDI paper...could this be the calcium phosphate.
Cleaning with acid removes all fouling quite effectively.
