A client wants to recover heat from the exhaust of two turbines to heat oil. The units drive compressors and will be normally running at a high load rate, although there are chances that only 1 turbine be running.
Normally I've seen one WHRU per turbine, but there is a suggestion to use a single WHRU for both turbines. I would like to hear your thoughts about this idea. I see that there could be some savings but reduced maintainability and maybe control complications.
Any idea will be appreciated.
