OneManWolfpack
A client of ours is having a pretty bad FOG problem at its WWTP, which is causing a number of headaches. One such headache is the build up of a floating sludge layer that shows up in the anaerobic selector tanks (see attached picture:
In the picture you can see a hose spraying the surface of one of the tanks. The operator does this to help break up and prevent the surface build up. The idea makes sense, I've just never seen it done before.
We're thinking of recommending a non-potable system to do what the hose is doing more efficiently. Essentially, we would run small diameter lines to the anaerobic tanks from the plant's effluent and install something similar to a building sprinkler system above the tanks.
Has anyone seen this done? Any ideas/advice?
Thanks in advance.
Thanks in advance.
