1503-44
Petroleum
- Jul 15, 2019
- 6,674
Getting at and producing that shale oil is basically what fracking is doing. Fracturing separates layers of shale to create void spaces allowing oil to collect and flow towards the well column. Prior to fracking being applied to shale formations, some shale oil was produced by surface mining of shale, crushing, heating and washing much the same as done with tar sand oil. Unfortunately generally considered a more environmentally unsound practice as large surface areas are affected. These are also expensive because of the large volumes of materials that have to be mined and the expenses involved in rehabilitation of those large surface areas after the oil bearing materials have been removed. Tar sand oils are high density, high viscosity and considered to come with high heavy metals content, which is why pipeline leaks involving tar sand oils are so problematic. And fracturing itself is troublesome, because of the fluids injected into the shale layers used to do the fracturing, of which some may migrate a bit too far away from the well and resist cleaning attempts before oil production actually begins. Plus, in some formations, the extent and degree of fracture is more difficult to control.
So fracking, and some other enhanced oil recovery (EOR) techniques, water injection, hot water, steam, CO2 injections, etc. have liberated a lot of that "oil in the ground", that oil which could not have been produced economically prior to the advent of EOR technologies, to which you refer. Unfortunately many of the wells using EOR are experiencing faster declines in production rates than those wells that did not require the use of EOR. It is thought that more rapid declines in EOR well production rates will tend to make much of the recent increases in total aggregate world oil production, but especially the USA total, which has increased mostly due to adding many fracked shale oil wells, decline that much faster as those wells come to end of life. And of course all of that work costs money, so the breakeven oil price from EOR wells typically have floors above $60-70/BBL even in the easiest to get at locations. Additionally EOR typically requires significant amounts of water and produce at least the same amount of contaminated water and mud, a lot of which is radioactive and which all of it must be properly disposed.
All in all, the best scenario currently looks like feeding the $GDP Beast is going to get considerably more difficult and expensive during the next 10 to 30 years. Interestingly the silver lining behind the Covid cloud, if there is one at all, may be that we might be able to learn how to significantly reduce HC consumption simply by changing some of our habits. We might also think of other ways to ease the transition off of cheap, inefficient use of HC. Tax air travel to fund high efficient mag-lev hi speed trains, but only where the two have coincident routes??? That's going to get a comment or two.
Dont worry about reserving oil production for petroleum processing companies, as they are the only ones that can turn it into useable stuff anyway, even if its only turning it into a feed stock for some additional use. There's hardly anything worse than handling crude oil, bitumen and tars.
