hai to everyone,
I need an idea for solving the following issue.
Its full of pneumatic signals.
1. A level switch mounted on the tank and having an pneumatic signal as input and gives an pneumatic output when level reaches high.
2.I have a Pnuematic actuator with valve in the outlet line of the tank,
3. Now if level high the valve should open and if the level low (means no output from the level switch) the valve should close.
So can anyone help me how to and what will be reuired to solve this.
the switch output will 15 psig
thanks,
symon
thanks,
symon
