Wanted - Animation monster
  • Thread starter Thread starter daveyk_belgium
  • Start date Start date
D
daveyk_belgium
Guest
In 2001 I have built a four-stroke engine using mechanism constraints, and everything works fine - I
I always use the mpeg encoder as this is what everyone can view on their computers.
I've personally never had any problems with this. The only thing that I can think of is that your graphic card is not optimised and that the renders that it has to produce is not adiqaute for the mpeg encoding.
That is justa long shot, but I would maybe try downloading the most current drivers for your graphics card.
Try to capture instead of MPEG in JPEG to a diferent directory, and use
some kind of animation bilder like divx or similar that will use tour
frames and compile the movie.
Hope I helped,
Paulo
I use the MPEG capture in animation a lot - only problem I have had is that it tends to run too fast when it is played back using Windows Media Player or Real One. Generally use Snagit now if I'm sending the MPEGs out to a customer because it maintains the same display speed as Pro/E.
Try changing the system colours to "black on white" - View, Display Settings, Sytem Colours, Scheme "Black on White". This will get rid of the blue background and remove the stripes. Improve the shaded resolution - View, Display Settings, Model display, shade, "Quality = 10" and "Show Small Surfaces". Also increase the Frame rate from the default 25 fps to 50 - file size is a bit bigger but usually not too bad.
You can open your assembly in Wildfire 2.0. You will have more options for mpeg playback speed, and probably better quality. If using 2001, make the viewing window the same aspect ratio as the mpeg output. Sounds fishy but it helps quality.
Camtasia Studio - We already speak about Camtasia many times
before, but Camtasia Studio is one very nice powerful tool for doing what you
need.
In the mid time I prefer to make real animations in best
programs for those purpose
