Want to know ’Force load’
  • Thread starter Thread starter jesband
  • Start date Start date
J
jesband
Guest
I am really happy to find this great place! Recently I have to struggle to handle with Pro/Mechanica. So nice!
Actually, as long as I know, I can get the displacement output once I set up any load as an input parameter. But what I want to do is to know the force when I give the known displacement information as a displacement constraint.
My understanding from other softwares like Ansys or ABAQUS is that I have only to get 'reaction force' at one point. Like I add one point by connecting a few rigid elements onany curve/line of the feature and then set the displacement constraint at the point and then from the analysis result I can get the reaction force at the point. That was my comprehension to solve that problem.
But I can't do that, for I don't know how to use that kind of rigid elements to connect between a line and one desired point.
Could you please let me know how I can get the forcecorresponding to the displacement input?
Thank you in advance!
create a constraint using the forced displacement option, then measure the reaction.
View attachment 971you
- add one point (PNT1)on the surface and one point (PNT0)underneath it.
-create a rigid connection between PNT1 and the surface.
- create a beam with a very high stiffness between PNT1 and PNT0
- constrain the point PNT0
- now you have your reaction force
