SLawlor
- Apr 27, 2011
- 2
I am modelling a buidling which has an irregular shape and many offset walls both parallel to each other and along their length (i.e. a wall which is longer or shorter than a wall above or below for the second case). Does ETABS automatically understand a connection between two walls of 300mm width offset by 100mm parallel to each other or is it required to use some method to "tell" ETABS of the connection such as using wall offsets. if anybody could help it would be appreciated.
Steven
Steven
