stevenal
- Aug 20, 2001
- 3,855
I have a possible answer to jghrist's question posted in thread thread238-37973 on Dec. 4th. Also a question.
jghrist: I agree that high side VT faults will be cleared instantly by bus protection, but how about secondary side faults? Secondary internal faults, and those located between the VT and secondary fusing could be cleared by a primary fuse if bus protection was set above this through fault value. Some unnecessary bus tripping could be avoided.
Now the question: What value of through fault current to use? I cannot seem to locate any impedance data for any of of our VTs. Anyone know where to find some typical values? I'm assuming there is sufficient fault current to burn a primary fuse, but I don't even know this much. Thanks.
