IEC 61869-3 for Voltage transformers categorises VTs in to Cat. A & B. Cat. A is with burden ratings not exceeding 10VA. Others are Cat. B.
The accuracy class declared shall be valid from 0-100% burden in case of Cat. A VTs and from 25% - 100% burden for those in Cat. B.
The standard insists for the linear characteristics between the said range. However, you may check the factory test reports of the actual VT of the manufacturer where you bought.
