SofieneFEA
- Aug 1, 2006
- 7
Hello Everybody,
As I know, the Von Mises Criterion is based on energy. “Von Mises” say that a point of the material (an elastic linear isotropic material) reach the plasticity when the energy (calculated at this point) resulting from the deviatory part of the stress tensor is equal to the energy needed to attain plasticity in a simple axial traction test.
The problem is that the Von Mises Criterion (the VMC) don’t limit (care about) the hydrostatic (same load in all directions in same time) compressions and tractions
The VMC assume that the material used have symmetric behaviour in traction and compression.
My question is how to determine the plasticity limit in case of use of other materials? (non symmetric behaviour for example..)
I think even ANSYS calculate only Von Mises Stress…People who work with ANSYS for example, work with the principal stresses? Or use the principal stresses to calculate other Criterions?
But, thank you “Von Mises”…and thank you for All.
