HI All, I am looking for some help on a vacuum testing application.
We have an application where we put sealed flexible plastic pouches into a vacuum tank that is filled with water. When you close the lid, it forces the pouch under the water, and then we slowly evacuate the air from the tank and once we begin to see bubbles forming at the edges of the seals. We record the in-hg that the pouch failed at.
My question is this.
Does the volume of the sealed pouch matter when we test it. Lets say we put the pouch in completely pressed flat and sealed it closed with barely any volume inside the pouch as opposed to giving a light breath of air to "expand" to the pouch then seal closed, not pressurized, but just opened up so that the volume of air inside the pouch is large, then allowing it to equalize to atomospheric pressure before sealing it closed
Assume altittude and temperature are consistant.
My thought is that because the volume of the air inside the pouch will expand as the pressure differential increases, the volume of the pouch DOES make a difference because the volume of air inside the pouch will almost double as the tank pressure drops in half as we evacuate air which would in turn drop the internal pressure of the pouch if there is room for that air to expand which is what is ultimately trying to force the air out of the seals.So as that air expands the pressure drops, which would mean ultimate the vacuum would have to be much greater to have that pouch fail than, if the pouch is already filled to the maximum volume of air before being sealed. Where in that case the tank pressure drops but there is no where for the air to expand because the pouches volume is already near maximum before seal, forcing the pressure to be maintained in the pouch, and exerting a larger force on the seals.
Am I on the right track with this though process?
