Volume of Excavation
McVities
Geotechnical
May 20, 2006
I'm trying to figure out the volume of an excavation. I could use other methods, but I am going to try to do this one in AutoCAD.
I know what the current surface is and what the final excavated surface will look like. If I could create these two surfaces then join them to find the volume in the middle, I would have what I want. So what commands/methods are best used to create these surfaces and then determine the volume?
Feel free to link and online articles, etc. that might help me with this.
Thanks,
McVities
You need to get urself a earthworks design package. I'm using Technocad. one can create upto 9 surfaces
AutoDesk's Land Development Desktop can probably do what you want, but you're asking way to much of basic AutoCad.
If you have contour lines drawn, you can measure areas in them and integrate the area to find volume.
Possibly you could rotate the axis 90 degrees and
start finding the area at different z depths at
a constant interval. Use 1/2 of the two areas per
each z depth and sum them.
dimjim has one of the method; my approach to an excavated hole would be to draw an area as a closed polyline representing the surface elevation of the hole, then extrude the hole depthwise with a taper. Do an inquiry for volume of the solid.
If the hole is not flat bottom and somehat rounded, union a sphere with the above solid at the center line of that sphere to get your hole shape then do an inquiry.
If it is a trench make a rectangular solid box and do an inquiry.
All values will be approximate which you would get with any of the program mentioned above anyway.
i
