Volume in NX 2
iYous
DE
Hi
I need to measure volume of a body after every step during a milling process. For explm.
as you can see in the Image- i want to drill two holes in a solid cube one after another and in between
i have to measure how much volume i have deducted in each step.
I have tried to save as IPW part, but i cant do anything rather than visualizing.
Have anyone an Idea. thanks in advance.
 http://files.engineering.com/getfile.aspx?folder=2b051e18-2182-4d13-9b64-ce8f9ee3ff30&file=Unbenannt.PNG
Right click on a feature in MNT and select extract body here. Then you can calculate the volume for each step.
Didier Psaltopoulos
Save the IPW, which creates a facet body, then convert the facet body to convergent.
Mark Rief
NX CAM Customer Success
Siemens PLM Software
Thanks i have nx 11.0.0 available.... will try to get nx11.0.1 and let you know :)
