Volume calculation (Bidirectional)
MaverickCATIA
Automotive
DE
Hello all,
I have designing a Rectangular Tank and have measured the actual volume by using the Split with surface and Measure option in CATIA.
I would now like to calculate the surface position from the bottom of the Tank for a Specified Volume (Opposite case). Any ideas on how to approach this problem.
One method I have found is by using the CATIA Product Engineering Optimizer but unfortunately I do not have any License for this module.
Thank you in Advance
a script might do it. move the surface position, then get volume adjust surface until volume is within tolerance
Eric N.
Glad to know that it can be worked out.
I have not used scripts before and trying to learn a little. However I am unable to implement what you have explained.
Could you please explain more.
Thank you
If your Split is done with a Plane and your tank, you can control the position of the plan with the script and get the value of the volume after an update and move up/down a bit according to value and target.
create the geometry, create a parameter that read the value of the volume. then record a macro that change the position of the plane.
That would be a good start. You can search the forum to find how to access the value of a parameter with VBA so you can check the new value after the solid update. Then you make a loop (I would do a While loop) until you get your volume within the tolerance you want. You can go without tolerance but it will be much slower.
Post your part and your code to get more help.
Eric N.
