LS,
When connecting analog output signals (4-20 mA) from flow computers or PLC's, we sometimes run into the problem that the voltage is too low for the input of the connected equipment. (We supply max 15 V, and some equipment requires at least 18 V on the input side). This is not due to the resistance in long or thin cables etc.
Is there a standard for 4-20 mA analog signals, about the height of the voltage to avoid these problems?
thanks,
DYV
thanks,
DYV
