We have a monitoring device installed at a 3-ph, 480V 3-wire delta service to monitor our disturbances. When a fuse on b-ph blows, the voltage on b-phase drops to 320V and the voltage on C-ph drops to 250V, but A-phase remains at ~480V. I would think that if the fuse blows on a certain phase, then that phase voltage would be close to zero and the voltage on the other two phases remain the same.
Can someone explain the theory behind this? Thanks.
