Voltage drop in service entrance wire
fastline12
Aerospace
Jan 27, 2011
306
I was recently talking with a design tech and we were comparing Vdrop data and his calculations were quite different from mine. I asked him how his were calculated and he said he was just using a PC based calc that someone gave him. Not saying his are wrong but I would really like to figure out where the discrepancy is.
Someone here willing to post a formula along with referenced data for the calculations?
Ohm's law, not just a good idea, it's the law.
But R is not just R, it is actually Z for voltage drop. The X:R ratio of Z may be significant and the phase angle of the I may be significant.
How about you post your formula?
Bill
"Why not the best?"
Jimmy Carter
Well, that is sort of where I am at in the calculation. I am thinking that some of these calcs have an engineered margin for PF of about .8-.9 which would certainly throw things. All calcs would be at 60hz. I will dig up my forumla to see if it gels. I think I worked it from the EE law side rather than the NEC code book side which might be where the issue is. I am not as concerned of the NEC data as much as I am concerned that I have done the correct calculation and accounted for all present conditions.
That is precisely what I was looking for. Thanks a bunch!
