Visual issue??
Runz
Aerospace
When panning a model, it appears to be rotating about some axis.
Also, my sketch views do not appear normal, even after I select normal.
Do I have a visual setting on that I do not know about?
Thanks,
Runz
MB2 on a piece of geometry it will move to the middle of the screen and that will be your piont of rotation. As for your sketcher problem go to Veiw/Render style and select parallel and that should do it.
Larry Spieler
Tool Design Engineer
Magee Plastics Co.
Check to make sure that you don't have Perspective Rendering turned on. View --> Render Style --> Parallel (or Perspective, depending on the style you want).
