I have a gearbox at my plant which is running hot.
I cleaned the heat exchanger on the oil cooler and have good flow on the water and on the oil sides.
I noticed the oil in the box is viscosity grade 220 and then consulted the OEM literature which recommends VG 320.
My questions is: Would using a lower viscosity oil than recommended cause the box to run hotter?
Thanks for your help.
