Virtual wall stiffness value's 1
321GO
Automotive
Jan 24, 2010
345
Hi Guys,
Simulate a flange support with a virtual wall.
Now, how does one calculate the stiffness of this wall?
E/t [N/m^3] is suppose to be the axial stiffness, where t is the wall thickness. Can one clarify this somewhat?
Can i also retrieve the stiffness with a test model? Suppose i would load a similar setup and measure the compression?
Would the stiffness then be: Stress / compression distance?
Greg Locock,
what do you mean with unit force?
Thanks you in advance.
Actually it isn't that simple is it? There'll be cross coupling between the deflections at each bolt.
Often it is worth modelling the attachment as well as the test item.
Cheers
Greg Locock
