virtual machining
  • Thread starter Thread starter ether2000
  • Start date Start date
E
ether2000
Guest
Does anyone know if it is possible to create a 3d model of a 3 axis milling machine with all its mechanisms so that it could be linked to Vericut to create some type of virtual machine?
thanks
I do not quite understand your question.. do you mean creating a program virtual machine (java environment) or merely programming to use Vericut on a a 3D model ?... Larry
I will be conducting a tutorial at the next Pro/USER in Florida showing the technique to do it : machine simulation using Pro/E Mechanism.
There are also techniques developed to export machine from Pro/E to VERICUT . See tutorials at :http://www.ptc.com/cs/cs_23/howto/evs8023/evs8023.htm
(you will need your PTC Tech support password)
Francois
in only few click's? :)))
will be good
