Viewing Entities
KnowClue
3
I have all layers on but cannot see any datums, curves, or sketches. I could see all these items before I did a SaveAs. Thanks in advance.
Did they disappear immediately after performing the 'Save-As' operation or only when you reopened the file?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Only when I reopened the file. The new one that is.
Are they Hidden?
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
I had this issue in past versions after a particular designer worked on a part. Somehow he had set visible in view layers specifically to a saved view in modeling. To fix I would right click in the window off of the part, click 'replace view' and select any one of the views that popped up and it fixed the problem. I never did figure out what was causing it to screw up, but that fix worked for me.
Jay Miklovic
Sr. Design Engineer
Edco Inc.
Jay, that worked. The only difference was, replace view did not come up with a right click. I had to select view, layout, replace view. Thanks very much.
