viewer
  • Thread starter Thread starter James2
  • Start date Start date
J
James2
Guest
Hi all,
I wonder wether it is possible for none Proe user to open a model and manipulate it (turn around, zoom in and out).
Like a viewer or some thing else
thanks
AutoVue does it. Its demo version is free to download.
By the way product view express is installed with ProE and it does the same.
Israr
Hi Israr,
Where can I find product view and/or AutoVue.
Thanks in advance
James
Edited by: James2
Hi Wsylvester,
I already found Product viewer from PTC.
But the problem is after I have download it, I cann't find it any more.
So mu question is how to find it and how to run it.
Thanks again
James
but file name is
pvx_install.exe
if you do windows
but there again if you opened and didn't save as then it should of installed itself, you can find that under
start>settings>control panel> general>settings>view objects
at least i think it should show up there.... i don't use it myself
btw James..I've been to Oostende ...but that was many years ago
There is an excellent viewer called 'eDrawings' available. The free version allows anyone to access and manipulate proE parts, assemblies, or drawings, so long as they are first 'published' as an eDrawingfrom within ProE. This 'publisher' facility is also free. The pofessional version, for which you pay, allows you to create eDrawings which can be measured, sectioned, and notated by anyone using the free viewer. I provide these eDrawings to both customers and manufacturers; they are an ecellent tool for manufacture or discussion. I include the following note, with the files, for my customers etc;
A free eDrawings viewer for viewing .eprt and .easm files may be obtained from http://edrawings.geometricsoftware.com/
Help this helps
HI ,I'm from china!!! Certainly there have many free eDrawings viewr for viewing.
i use the (deep exploration)tool to do that!
Help this helps
Definitely recomend eDrawings, if you save as eDrawings Executable Fikles(*.exe) then it can be viewed without having any software installed.
I agree with what Lee writes about eDrawings.
But I think he forgott to mention one of the best features: the publisher can make an exe-file wich includes both the 3D-model and the viewer!
Then the receiver of the file doesn't have to find and download anything!
Hi guys,
I'm so sorry, I have download e-drawing but it doesn't work for Proe.
Only for autocad drawing.
So.......I still have none
James
James, you cannot view the native ProE file with the eDrawings viewer. First you must create the eDrawing (which will have the extension .eprt or .easm, depending on whether an individual part or an assembly) by using the eDrawing publisher. After installing the (free) publisher you will find a new icon on your ProE main toolbar which allows you to publish the required file. I currently use Wildfire 3, and also used it with previous versions.
ProductView Express is the best option as it does not require any pre-publishing of your data. If your data is under PDM control, then you will have to backup the files from Pro/E for PVX to see them. PVX is a plug-in to IE, not a standalone program.
Hi guys
both options are best. Product veiw express is best to visulize a pro user, and edrawings is best for all related persons or vendors/suppliers who are not pro users. u can download edrawings by website. and for product veiw express, just open side panel(browser) in wf window or go folders tab and click on any part or assy file, the product veiw express will install automatically for the first time and then u can view files in internet browser by double clicking it or by rmb>>open with pvx.
The ability forPVX to view the pro/e files depends on whether the correct information is embedded in the pro/e file when you save it. To do this the following config options have to be set;
save_drawing_picture_file
save_model_display
Viewable files are often huge in size when compared tonon-viewable versions.
Hi Kwillo
the option 1 isonly for preview of your drawings and also control opening preview of drawings. the option 2 is always brings your last display when ever you open your part or assy file again. if u dont set these, u can easily preview part or assy files with pvx.
