1
- #1
I'd like to set up a default view orientation called "Isometric," "Trimetric," and "Dimetric." SWorks has this already programmed into it, and it's a very simple "two clicks and done" operation.
What kind of convoluted command sequence do I need to apply so that I can easily select the view as a standard view? Since it's not pre-programmed, I imagine I'll need to actually crete the view... using the "orient" tab in the view manager, then create new, define as "dynamic orient." You might suggest using preferences instead and selecting the word isometric or trimetric which is in the drop down menu. However, these views are not correctly oriented by default... so making your own is necessary.
If you do the math to determine which angles you need in order to produce these views, then input those angles into the dynamic orient fields for each axis, the view is still incorrectly oriented.
Has anyone figured out the magical numbers to enter to trick ProE into producing a valid orientation in this fashion?
Thanks!
Thanks!
